OK Motor heads! 454 4 bolt...
![Post](/forums/images/icons/icon1.gif)
You may want to see if they have a build sheet on the engine. Marine clearances are not the same as roundy-round or drag strip motors. It is unclear to me if this was built as a marine engine or drag motor. It is my understanding that Eagle is middle of the road quality for forged components. Good Luck
Mlitefan, 10:1 cr with iron heads is running a little too close to the edge...if you get some not so good gas it could cause the engine to burn down (detonation).
As it has been said, it is unclear if this motor has been built for marine use.
So, first thing is check for brass freeze plugs, which has also been said.
Ask if it has inconel exhaust valves.
Get cam specs. With a 461 and 10:1 you can run, for example, Cranes hyd roller 139741 but I would suggest nothing higher.
10:1 is fine, and quite frankly suggested for that cam, as long as you're trailering.
That way you can fill up at a regular gas station and get 93 octane. Don't go above 32* total timing. My opinion is you'll be fine. If you can get Sunoco Ultra 94 you can run all 36* of timing.
I don't trust marinas as much.
If you want the full effect of that motor exhaust is really a must.
The above cam is the absolute biggest I would suggest for a 461. It's a 234/242 112 .610/.632 and has 14* of overlap at .050.
That's plenty to cause reversion if you don't have good exhaust.
Also check the ring gaps and bearing clearances. As long as their not way outta wack you can most likely use it for a boat.
And last, make sure that is has Fel Pro 1027 or atleast something similar.
If you do decide to buy it, just lube it up real good and put some oil in the cylinders, prime it with a priming tool, turn it over by hand a few times, with the oil in the cylinders, (spark plugs out) and if you want to go an extra step, turn it over a few times with the starter and no fire to it.
As far as the comment of the valves sticking to the seats, if the builder has any clue, you always put oil on the stem and seat of a valve when assembling them. So, I wouldn't worry too much about that.
DAVE
DAVE
how about marine head gaskets unless you are fresh water cooled. I used fel pro marine head gaskets. You might want some type of baffel in the oil pan for marine use.
If there is a good written guarantee I would consider it. Without a guarantee and two years old I would pass and build a motor that suits you.
good luck
good luck
Thanks everyone for the input...I think I am going to pass on this motor. Just a bit too radical for what I am looking for. 89 Octane is just about it on the lake I spend most of my time on...
On the advice of several posters, I gave Bruce a call this weekend and I liked what I heard!
SteveW If you can get that at 5000 rpm's without a blower you are a real genius. I would be very interested in what the specs are and if it could idle and shift at 800 rpm's. Ironman
![EEK!](/forums/images/smilies/eek.gif)
nobudget
3
06-05-2002 03:23 PM
