K-Plane question
K-Plane question
What would happen if I were to take K-plane's that were made for a twin engine boat and instead of mounting them high on the outside corners of the transom, I was to mount them closer to the drive and they would be lower on the transom. Would this be a bad idea. I have seen it done once on an F-1 fountain but do not remember what team it was. What effects do you think would happen?
Were doomed!
You still have to take into consideration the degrees(?) the drive turns from left to right when mounting them. Thats why some tabs have the corners cut to clear the drive when turn fully. Personally on a pleasure boat i would leave them on the outside......its easier to balance the boat out if you have lots of people aboard and the boat lists to one side when the tabs are on the outside edges...think about it.
-Wally
-Wally
Charter Member #232
I have talked to a bunch of racers about this and they have all said get them as close to the middle as you can. No one really ever told me why but the best I can figure is when you are running WOT the boat is fairly high in the water. The tabs will be wet for longer mounted farther to the center line. You will also get less of a chance of over tabbing in a turn.
Jon
Jon
Put your best foot forward!
Yes, I have done this on a 251 Convinsor. Moving the tabs in as close to the drive as possible helped tremendously with the chine walk it previously had. As Audiofn said I think alot has to do with the fact that the tabs are in the water longer. I did not lose the ability to "Level" the boat. And I gained MPH because I can control the boat better. My 2cents
