bore size?
Charter Member #655
whats the largest I can bore a Gen 5 454? can I sleeve it and go really big???I'm .030 over now whats a safe bet? Dont want to weaken the block too much......
Charter Member #655
I just was wondering what size cubic inch I could manage without trashing the block I'm planning on building some 4.25" stroke motors next time around......060 over with the 4.25" crank is a 496 right?
If your boat has a sail do you ride a horse to the ramp?
Before the 502 came out, a lot of guys were building 496's. If you need to in the future you should be able to bore it once more. .080 or even .100 is possible on some blocks. Just have it sonic checked. I had a 427 in a 68 Vette bored .100 with a solid lifters. Revved it 6500 on many occasions.
Hee's what you do Dyno. Punch the first one out until you hit water and sleeve it. Then just don't bore the others as far,,,,,,,,,,,,,,,,yeah, I thought you'd like that,,,,,,,,
I know quite a few bowtie blocks that have gone as far as 4.5 which is .250 over. Personally, I wouldnt go over .060 without filling at least some of the water jacket to give it strength
