How to pull a motor? >
Old 10-19-2003, 05:36 PM
FunHome's Avatar
Why do you have to pull the Drive?? I would think if you could losen the motor mounts and bring the motor forward just a little then you should be fine with out removing the drive.......
Let's just say I've seen it done this way many times.....
Was it "the wrong way?"
FunHome is offline
Old 10-20-2003, 06:59 AM
Leathl_WS6's Avatar
Originally posted by formulafastech
Yes, with stock Merc mounts, there are 4 bolts. Alignment is easy to check. There are a bunch of good threads on OSO about it, that can explain it better than I, if you do a search. As far as the coupler, you can check the splines, and also, you should be able to see if the rubber in it has been hurt, by looking at it. WIth only 50 hours on it, unless you hit something hard, or did some serious beating on the boat, its unlikely that its hurt.
Ok thanks. Also the motor has 50 hours the boat has 370. I just bought it so I'm not sure how many hours on the coupler. I would guess 370.
Leathl_WS6 is offline
Old 10-20-2003, 09:31 AM
Charter Member #737
KCHOTBOAT's Avatar
I do mine that way all the time.
KCHOTBOAT is offline
Old 10-20-2003, 12:10 PM
FunHome's Avatar
Thanks Rich!! I there for a second I thought I was the only one that was doing it that way!!
Gordo, does it a little different yet, he pull the two back bolts that are near the coupler, that face down, but when going back together it was hard not to drop the spring washers!! I have done it both ways, undoing the bellhousing and gordo's way.
The fountain had TRS drives, and they spoiled me!! It was easy, just undo the tranny's and motormounts and pull!! Funny thing though, the first time we pulled the motor's in the fountain, someone said we had to pull the drives also....Now if you were pulling the tranny's it would be different..
FunHome is offline
Old 10-20-2003, 01:48 PM
Leathl_WS6's Avatar
So if I don't pull the Drive what is the process for getting it out. I have the whole interior removed so space isnt an issue.
Thanks Rob
JRider
18
08-28-2008 12:49 PM
Strip Poker 388
02-07-2008 12:15 PM
thanks_don
15
09-23-2007 11:06 PM
custom29scarab
25
10-22-2005 06:39 PM
Quick Reply: How to pull a motor?
