How fast is a 96' 22 Scarab with 502/415hp?
#61
Originally Posted by Whiteknuckle
I don't understand why they are not still making this 23' Scarab, or someone did not buy the molds for it after Wellcraft stopped making performance boats. It had to be the most effecient hull on the water. In fact, it sound like they were pretty close to rewritting the physics book. Remember, the prop does not care what is making it turn, whether it is a 502 or a 283. At 5000 engine RPM with a 1.5:1 drive and 25 inch prop, the speeds I am hearing here are very remarkable.
#62
Originally Posted by boatn70
yeah them ally outboards will open a can of whoop azz in good water wont they!!
#63
robyw1, what kind of mods did you do to your MPI engine, and what kind of performance increases did you see?
Steve
Steve
#65
a higher x dim really makes a big difference on the 22 scarab, had abuddy with one 385 hp 25p x dim raised 2 inches, 74 mph
#66
Steve
Steve
#67
What's the fastest 22 Scarab you have heard of ? Do they get squirrelly? Tab's, Hydraulic steering? I was thinking of a shorty -1. Doug
#68
Originally Posted by nitro/max
My 23 SCS was the orange one too.
http://www.isphub.net/Wayne/personal.htm
#69
anyway I kinda like this one
http://www.hotboat.com/classifieds/a...rab%2023%20SCS
![EEK!](/forums/images/smilies/eek.gif)
#70
Steve
Steve
Walbro 255lph fuel pump
Adjustable FPR
TB gasket modification*
* in the 7.4 MPI if you open the throttle wide engine off you can see down the throttle body bore and notice that the gasket blocks almost 1/2 of the bore. I removed the throttlebody and cut the gasket perfectly round and replaced the throttlebody. This modification alone didn't increase performance until I increased fuel pressure.
In my particullar case I couldn't get a big increase in fuel pressure until I replaced the pump. I don't know if my pump was bad or if it was just a cheap, restrictive pump.
After those mods alone I would estimate I picked up 25-30 Horsepower. That is just an estimate. The power over the whole RPM range seemed to be up.
However Let me caution you about this engine. It won't take too much power before it self destructs. This engine has brittle cast internals and RPMs MUST be kept below 5000.
I'm not going to be doing any further mods to this engine because I feel that it is pretty much at it's limit. I want the thing to last. There is actually a Whipple supercharger kit available for this engine that boast close to 500 Horsepower. perhaps they know better than I what this engine will take.
Roby
