Darin/Houston Prop - What's this?
Originally posted by HOUSTONPROP
...the new acclerator blade design...
Its a stock, Mirage plus prop that after labbing the prop and making custom or hidden changes to the prop ,it works better than ever.
And will set you back in the seat with improvments of best of both worlds.
quicker to plane
acclerates hard and fast
mph gains of 2 to 3
you can have weld in hub inserts for extreme high hp
stainless drop inserts, avaliable per request
its sharp and shiney and Fast
it's smooth
it does not blow out
and you can trim to very high angles for reduced drag
WE CAN BUILD ONE OR MODIFY YOUR PROP/
prop is redesigned by Houston Propeller.
AND I CALL IT " THE ACCLERATOR PROP....
quicker to plane
mph gains of 2 to 3
it's smooth
also to add ,I have taken some raw castings,worked it to the Mirage Plus pitch block,made my trade secret changes and wham-o - you have it.
THE ACCLERATOR PROP BY HOUSTON PROPELLER.
Darin
Darin
![Talking](/forums/images/icons/icon10.gif)
Originally posted by IRONMAN
How would it compare to a labbed bravo 1 at approx. 80mph on a 4400lb deep V?
sure it would run faster but it would be HOLD ON
WHAT pitch B-1 are you running?
Darin
![Post](/forums/images/icons/icon1.gif)
Chris the hydro is a stern lifting prop,where this prop is a bow lifting prop big difference.
27 ACCLERATOR PROP would be quicker out of the hole and midrange would be alot quicker and as far as top end just depends on how far you go.
Darin
![Wink](/forums/images/smilies/wink.gif)
Darin
