Max RPM for 350 MPI? Safe
I'm not so concerned on the actual speed, but more so, the amount of speed increase I would get from these changes. I'm not sure what places like Houston Props are getting for a labbed prop like a Mirage 3 blade. I'll have to check into it. I think the performance gain would be worth the money. thanks again,,, Justin.
Houston did my prop and Im getting great midrange speeds plus my new top speed is 55 gps at 4700 rpms
in a 4000lbs 25 foot boat running a 1992 350 mag
21p laser II labbed
21p laser II labbed
1992 mag 350 270hp at crank 250ph propshaft
now I have added EMI's thru hull K&N AIR with a Snub stack, and bumped the timing I would'nt expect that to all together produce a extra 10-12hp not a whole heck of a lot.
but Houston worked my prop and with that and those mods I went from 49 to 54 gps sometimes 55 if 1/4 fuel
I attribute about 3.5 miles a hour to houston and the rest to the minor mods
I want to switch to a BB bravo , but the minute you change the drive to a bravo you need a extra 20hp to overcome the drag of the bigger gears and case
I am hoping to find a happy medium?!?!? somehow... Very good point though. I have trim tabs to get me on plane quite easily, fully loaded, but I'll just have to try diff. props and see what happens. Thanks again, for all the very helpful info!! Justin
Tidal Sails
12
07-31-2007 02:40 PM
Tidal Sails
1
07-03-2007 04:43 PM
