Change to Synthetic Oil. Have questions
I would like to change to synthetic oil, but I am wondering how to get the old oil out completely as I understand you should not mix the two. I have to suck the oil out the dipstic so I do not get it all. I also don't think you drain the oil cooler and lines completely. Is it necessary to get it all out? I know there are a number of you out their that have changed to the synthetic oil, so what did you do?
Toxic FORMULA
I've broken new engines in with reg. oil and then switched to syn. with no problems. If it really worrys you , only run it a few hours and change it (and filter) again. What's left at that point won't be worth worrying about.
ttt
should you use the same weight oil with synthetic? I have stock 502's 425hp am thinking of switching to mobil 1. is any one syn better than the other? Also, does the frequency of oil changes differ?
No need to sweat about getting the old oil out. They'll mix with no problems.
Yes, use a synthetic with the same "weight" as conventional oil. Synthetics are actually different in the way their viscosity behaves at different temps and such than conventional oils, so they just stamp on the can what conventional oil the synthetic behaves like.
(synths remain pourable when cold and do not lose lubricating properties at the same heat ranges as conventionals).
In a boat, your oil change interval is set by the need to remove contaminants in the oil from blowby and combustion byproducts that get in the oil and remain in suspension by the detergents in the oil - not from oil breakdown. Therefore, the fact that synth oil will last far longer before breakdown is not a concern, you gotta change out the contamination on the same schedule. This means that oil change intervals remain the same.
Use cheap oil for your change before winter layup and then change it again after a couple of hours in the spring to your good stuff.
Charter Member #34
Not A Problem.
I ran the Merc stuff in a Baja 212 with 454, a 272 with 502 and the 36 with 500's until 20 hours on each.
Then I switched to Mobile 1 15W50 in each, using the Fram HP4 filter and sometimes the Merc Racing Filter.
I have received VERY good service out of all these engines.
Don't worry about making the change.
Offshore Cowboy
Originally posted by Dock Holiday
Not A Problem.
Not A Problem.
