350hp wants more horse power
Travis I would love a pair of those. A pair of your current engine would be awesome also. The fuel would be a drag. I have a 120 gallon tank. It would take alot of gas cans lol.
Have you been happy with your exhaust? I am thinking about changing. Also have been thinking about changing to a carb. What cfm are you running? Thanks Dwight..Hppy Tday.
Originally posted by twinn29
Cool thread- Trav- what are you planning for the 570??.......doug
Using pretty much the same setup, of AFR heads, victor jr intake adding a 800 holley. and a 12.6:1 comp ratio and a big solid roller.. She runs on 110
![Wink](/forums/images/smilies/wink.gif)
Whitey.. i am very happy with my EMI's no problems yet. Right now I am running a 750 holley, but changing over to a 800 holley
![Smilie](/forums/images/smilies/smile.gif)
I see if I can remember, That was two motors ago LOL!
I had JimV ( jim valako) do them.
Had them machined for 7/16's screw in studs and guideplates.
Had the valve guides machined down to take the lift of my cam and accept a small teflon valve seal, so they would fit inside my springs.
that was about it.. i would not run any motor that had pressed in studs, in my mind all this is cheap insurance
My opinion, if your on a fixed budget, the vortec heads are the way to go. They flow great and are only about $260 each. Alot cheaper compared to the $1850 I payed for AFR heads, but AFR heads are gorgeous peices![Cool](/forums/images/smilies/cool.gif)
got the vortecs from a buddie-$400
Machine work from valako-$225
springs-$125
retainers-$55
locks-$35
seals-$25
7/16" ARP studs- $75
guidplates-$24
= $939 Springs, retainers, locks were to match my cam.
springs-$125
retainers-$55
locks-$35
seals-$25
guidplates-$24
thanks Travis, I am thinking about having some work done but, have to weigh out the cost. I have seen some pretty good deals lately on heads and wonder if it is better to buy with the heads already done. Atleast this gives me a idea of where I am at as a starting point. Dwight
LubeJobs42
01-29-2006 08:23 PM
loosecannon22
01-07-2003 08:44 AM
