Exhaust Hole Spacing BBC vs SBC >
Old 11-28-2003, 09:23 AM
Pat McPherson's Avatar
Question Exhaust Hole Spacing BBC vs SBC
I know of two fellow boaters that are considering re-powering with the new 320HP/6.2 small block rather than reworking or replacing 330HP/7.4 big blocks.
How different is the exhaust spacing? Will some off-set pieces need to be added to line up to the holes in the transom?
Patrick
Pat McPherson is offline
Old 11-28-2003, 04:50 PM
formula31's Avatar
Going from big blocks to small blocks!!!. What are they smoking? Forget the Hp numbers. Boats work on torque. And the cost must be amazing. Unless they are very small boats why lose the cubic inches.
formula31 is offline
Old 11-28-2003, 06:08 PM
Well, one of the boats is an older 29' Formula and the owner has heard that that boat will be much better balanced with small blocks, and defiantly faster.
As for the new 6.2 vs. a low output 7.4; I can say that I have run side by side with a fellow that has the same boat as me. He has the 320HP/6.2MPI, I have a 310HP/7.4MPI... He goes right by me. I am thinking that new 6.2 has just as much torque.
I plan to add a little more juice to my 7.4 this winter, so next year should be different...
Patrick
Old 11-28-2003, 10:09 PM
formula31's Avatar
better balanced I would agree with. I dont have any experience with the 6.2 so I shouldnt have shot my mouth off. I just have found that when you repower a boat, the bigger you go the better because you will want it to go faster in 2 years.
Old 11-29-2003, 07:44 AM
MarineKinetics
rmbuilder's Avatar
Pat,
For alot less money he could have two custom marine 383's built totaling an easy, turnkey and reliable 750 hp. And lets not forget the 700 lb weight savings over the twin bigs.
Bob
rmbuilder is offline
Old 11-29-2003, 07:50 AM
700lbs? Got some aluminum in those babies? I thought it was about 200lbs each...
I would agree that the 6.2 is pricey new, 8K+, but in classifies on OSO, 5K can buy one...
Can anyone answer my exhaust question???
Patrick
Old 11-29-2003, 08:35 AM
MarineKinetics
rmbuilder's Avatar
Pat,
Sorry. Added the 350 twice! Call it 400 total.
Old 11-29-2003, 02:30 PM
PAT, BB HOLES ARE UP AND OUT AROUND 2 INCHES FROM SB HOLES. I UPGRADED FROM SB TO BB AND HAD MY OLD HOLES FILLED IN AND RECUT WITH JUST THE TRANSOM PAINTED ($300). THERE IS A DIAGRAM IN MERCRUISER MANUAL THAT SHOWS THE DIFFERENT CUT LOCATIONS,HOPE THIS HELPS.
CONDOR24 is offline
Old 11-29-2003, 02:43 PM
Rob
Strip Poker 388's Avatar
Not enough weight differance. to out weigh the tourqe diff.I would stay with the big blocks. the 330 are good motors Just up grade to rectangle port heads and buy rebuild kits with a little better cam and have over 400 hp.
I dont know the diff >its sound like you allready made your mind up on the sb.
Good luck
Rob
Strip Poker 388 is offline
Old 11-29-2003, 02:55 PM
Rob
I bet you could find some one to swap .Somebody wanting to up grade to big blocks. Remember The small block exhaust and tail pipes are smaller.
Quick Reply: Exhaust Hole Spacing BBC vs SBC
