Crossover vs Water Pump
#31
Toxic FORMULA
Originally posted by BROWNIE
As to the 20-40hp BS, how much horsepower could you possibly put through a fractional hp vee belt?
![EEK!](/forums/images/smilies/eek.gif)
![Roll Eyes (Sarcastic)](/forums/images/smilies/rolleyes.gif)
#32
I purchased and installed a cross-over on my `98 7.4 MPI. I have the single serpentine belt. I got the type with the idler pulley made onto it, for use with the serp belt.
The results:
I saw nothing.........
The main reason I went with the crossover was partially cosmetics and partially to rid myself of my leaking circulating pump. $500 clams later, I need not worry about circ pump failure.
It sure is purty, but save the $500 for something more revelent......
The results:
#33
not to forget the new kit that gets rid of your circ. pump has a idler, well it also has a bearing in it that can still go bad, me I just change my circ. pumps every three years are so and you will not have any problems, impellor drag in a cicr. pump is costing you maybe 7 to 12 hp. . leave it along unless you have big horsepower with a pressure are a overheating problem
#34
If a person wanted to go with a crossover on a single application, would he need to get a pressure gauge and a different t-stat housing?
#35
Ginger or Mary Ann?
Always use a pressure gauge when changing from stock design.
#37
have run 3 different crossovers, no issues at all, if you run without a bypass and themostat will run very cold usually...my procharger setup requires their crossover...
