thunder bolt dist.
Charter Member #655
thunder bolt dist.
anybody got a couple they want to sell????putting SuperV's motors back together and the distributers seem real sloppy can they be rebuilt? and if so what does it cost? I think its time for MSD's but checking all possibilities thanks
Don
Don
If your boat has a sail do you ride a horse to the ramp?
Actually 2 o-rings. The distributor lower body had 2 cast collars that the oil supply for the lifters runs between. I think the MSD distributor has these collars fitted with o-rings too. The o-rings just cut down on the oil loss in a stock distributor to the lifters/push rods/rockers. The little hole allows some oil to lub the dost gear. Ut might be overkill. Im sure somebody has an opinion on it. I figure it was a good idea. I had the equipment to do it, so why not.
[ 01-17-2002: Message edited by: formula31 ]
