pistons
Charter Member #737
The heads are stock square port which I am planning on getting ported and polished. I found someone in the are that has a flow bench. The cam is a roller which I had in my 540 I still need to find the spec sheets on it.
Dyno, do you have to use 92 octane all of the time with that 9.6 to 1? I forgot, are you using aluminum heads? Just curious. It's hard to get good premium on the water sometimes.
