why do engines burn up when run lean
It is the high oxygen to fuel ratio that acts like a blowtorch. When you ad the hammering that occurs during detonation (another by-product of a lean burn) then the pistons and head gaskets tend to change shape. Hint: it is not the shape you need to make power.
Roby
Roby
mcollinstn, Whipple Charged, Tomcat, I have learned alot on this board over the past few yrs, But I have no idea what the hell you are talking about!!!!!
How's this for a summery, Lean=Heat=Melted pistons and stuff
Toxic FORMULA
Offshore Cowboy
Since no one's given you a hard time yet... I will!!!
Answer: The same reason jalapeno's are hot!!!!
Better Answer: Duh!
Best Answer: Friction -- Ya know.... the thing that's lacking in the two brain cells you DO have!
Better Answer: Duh!
Originally posted by Joe
Better Answer: Duh!
Better Answer: Duh!
What would I do without your expertise. Next time I will email you direct for the answer
Re: why do engines burn up when run lean
Mcollinstn, you mentioned aircraft engines. Continental Motors Corp (TCM) engine operation manuals have encouraged running some of their aircraft engines on the lean side of peak EGT for many years. Most pilots prefer to lean the mixture to peak EGT and then richen the mixture to 50 degrees below peak. This is what's in the POH of the Lycoming-equipped aircraft I've flown.
This time of year aircraft engines run fantastic due to the cold air temps. Just imagine making 110% of rated max power in the cold air.
A to Z
Originally Posted by mopower
And then there's DIESELS That run chit gas...constantly lean.... 20+:1 comp...NO spark...and tack on a turbo. This defies physics
actually diesels run on a pretty basic physics idea, which is why they work so well and are almost impossible to break..... 20:1 compression, 40-60 PSI of boost add a shot of nitrous in there for fun and then run the whole thing on propane, kerosene, multiple grades of fuels if you want and watch it just run and run and run.... plus make a ton of torque in the process... try any combo of two from the above and you will be picking up parts off the street.....
