Acclerator Prop Delivers
Originally posted by HOUSTONPROP
there is a 27 Mirage plus on there right now with 11 hours left for 99.00 no current bids and the time is
4
4 central time ,
YOU BETTER HURRY !!!!!!!!!!!!!!!!!!!!!!!!!!!!!
YOU BETTER HURRY!!!!!!!!!!!!!!!!!!!!
27 LEFT mirage pluus on e-bay 99.00 hurry hurry!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
4
![Embarrassment](/forums/images/smilies/redface.gif)
![EEK!](/forums/images/smilies/eek.gif)
![Roll Eyes (Sarcastic)](/forums/images/smilies/rolleyes.gif)
One question and maybe a dumb one at that. Being that all props are different should I run this 27 mirage plus to get some base line numbers before we look at reworking it. Probably January or February before I can get that opportunity.
![Mad](/forums/images/smilies/mad.gif)
Thanks for the reply. Sorry about the misunderstanding regarding the remark "do you buy fast props, and install rings to slow back down" I was referring to me and the others that have changed props, only to later have to install these "rings". and then be back where we started. Also I stand corrected, the boat had Bravo props, (not labbed) not Mirage's. If you were to rework the Hydro's, you indicate the "blowout" would be improved, however would there be a loss of top spreed? I realize there are no guarantee's, obliviously your word and best intentions are just as valuable.
no problem,as far as loss of speed ????
the honest answer is I do not know for sure .
it could run faster,may run slower?
but would surley plane out quick ,with little blowout,
I am pretty sure what needs to be done in my mind
what to do to make them plane quick and keep the rpm and speed up.(Thats the GOAL.)
if not we can always put them back where they were,and try something else,you only pay -once at my shop. we will get it, until we hit the mark.
what pitch B-1s did you have ?
Man, would it be awesome if Cigarette was half as responsive as you guys (Houston Props). The B-1s were 30's. Can't ask anymore than you have offered. Will get the props off the boat (stored) and contact you direct.
Many thanks, what a pleasure!
![Question](/forums/images/icons/icon5.gif)
it just depends on what you need ??
more or less can be achieved ,but there is a maximum of 600rpm's each way.send me a pm and let me know what you are running ,where you are at for rpms and speed and what would you would like to achieve.
Darin/
talk to you tomorrow
Darin/
Gone Fishin'
Darin
can you make accellerators out of Quicksilvers (25")
or would they be "trade ins"
i have stock 330's on a formula 272. 4500-4600
64mph top speed/
I want same wot rpm, same cruise (40mph at 3000rpm) but top end gain
is this the prop for this, or labbing and cupping my quicksilvers, or start over with something more modern
thanks
ramb
64mph top speed/
thanks
ramb
