The Basics of EFI Conversion
I was planing on mounting the ecm next to my msd box on a plate that i have mounted on the back of the bell housing. after reading I am now concerned about mounting so close to the coil & msd box. anyone got ideas where i should mount it.
The Holley efi intake has some ears where the fuel rail can be mounted. In looking at the fuel rails there are no brackets to fasten them down. I can make my own brackets but is there anything special I need to know?
After reading about the NA 540's dyno test, which is my motor but with 335cnc AFR heads. & only 8:1 compression I started running my numbers I see where my fuel pump will not be big enough to handle the HP. I am looking at going with Aeromotive eliminator fuel pump & regulator. Do I plumb out of the fuel pump to a t-fitting then to the front of each rail, then put the regulator on the back side of the rails & return the unused fuel to the tank?
anyone interested in fuel injection should have this web site memorised. www.lindertech.com. Jim Linder is one of the leading fuel injection minds in north america. He has injected just about everything you can think of from hot rods to lawn mowers. He is a terrific technical instructer and a dam fine cook too
Also a great supply place for things fuelish. and the worlds leader in injector rebuilding and blueprinting.
![Smilie](/forums/images/smilies/smile.gif)
Turbo Tim, is that you???
Joe D. (320efis)
Joe D. (320efis)
These injectors are the best that money can buy. I love them and they have never given me any problems. When building a high HP engine I wouldn't dream of using anything else.
http://www.rceng.com/
I went to Marren Fuel Injection's website. They have a neat interactive injector calculator that tells you what size injector you need for the horsepower you make. It can also tell you how much power your injectors can make if you know how big they are. Go to www.injector.com. On the menu on top, click on information, then on injector selection guide.
Things are going, well unfortuatly I've got to pull one of the motors again, it seems like the rings did not seat or one of the pistons has a hole in it, I'll know once we get the heads off. This time we will dyno both engines before they go back in.
I'm going to paint the engine comartment white while everything is apart, and I'm sure it won't stop there....
I've been day dreaming about running out to Block... it's the only thing that keeps me going while I'm wearing long johns and three shirts
Glad to see you made it to the web site
Charter Member #40
For what it's worth I used the Marren folks to I guess what you would call blueprint some injectors and they were fine to work with. Also used Kinsler alot as I ran the Kinsler 8 indiv runners and they were great and very competent but expensive. The FAST people were super and the system worked very well!
