Shifting problem
I just purchased a new (used) boat and I'm having trouble shifting into forward gear. It seems as though the cable is adjusted just a bit too loose. There is no problem going into reverse or neutral but into forward I have to really push the gear lever ALL the way forward in order to get it to engage. Once engaged it never pops out. Is there an adjustment screw or something that I can do to try to correct this? The ****er is a Zero Effort control. Any help would be appreciated.
speel chekk this fokker!
soudsn liek you might just need to adjust the littel end thining on the cable. If you have gaffrif shifters its pretty easy to adjust them.
Pardon me, while I whip this out!
Something sound wrong with that. Maybe something is loose on the shift plate. Compare the operation of one to the other while having a helper move the sticks. If a pivot bolt or something came loose you would get this result.
Hoping for the easy stuff, good luck
Dave
![Smilie](/forums/images/smilies/smile.gif)
Dave
B-MAX REPAIR
YOU MIGHT CHECK THE SHIFTER UNIT IN ENGINE COMPARTMENT. MAKE SURE NOTHING CAME LOOSE AND THAT THE SHIFT THROW IS CORRECT. THERE IS A PLASTIC GAGE THAT MERC MAKES TO SET THE THROW. RB
check the shift brackets first. If they are noraml then go to livorsi.com (gaffrig) and they have teh instruction sheet on how to adjust the throttle cables on the shifter
