prop options
Some more information would be helpful;
Engine
Current rpm at WOT
Speed at WOT
Attitude of boat
Does the prop ventilate (blow-out) while getting on plane or in turns?
Matt
Throttle Up Propellers
877 842 6855
Engine
Current rpm at WOT
Speed at WOT
Attitude of boat
Matt
877 842 6855
97 Baja Hammer
actually you have the best prop for your boat,The Mirage Plus is a great prop.
David there are some changes that we can make to the propeller to increase the overall performance.
even if it takes thinning of the blades ,changing pitch,adding cup to the blades or even rake,give me a call and I will glady go over the boat ,motor ,prop setup to get you dialed in for the BEST PERFORMACE TO BE ACHIEVED.DARIN
