Is there anything that dissolves Silicone glue?
![Post](/forums/images/icons/icon1.gif)
I am re-mounting my new GPS Speedo and the previous installer used silicone glue to mount it with. Subsequently I have glue on my powdercoated trim ring that I need to get off without messing up the finish. I have carved it down with a razor knife but need to go further. Any good solution that will remove this stuff?
Thanks - Ray
[ 01-25-2002: Message edited by: Raypanic ]
Thanks - Ray
Ray
Ray
Were doomed!
![Thumbs up](/forums/images/icons/icon14.gif)
wd-40 works ok for takeing glue off
or you can go over to BoatUS and get some stuff called anti-bond....works good too.
-Wally
-Wally
Charter Member #737
I have used acetone on all my powercoated parts. My friend owns a powercoating business and that is what he uses to clean the tape residue off the new parts he does.
Charter Member #601
Raypanic ,
If you use your thumb and press a bit you can sometimes roll the RTV off a slippery surface such as power coating. Takes some elbow grease, but I have done it. On a trim ring that wouldnt be that much work.
Good luck, let us know what works..
Dick
Dick
