oil drain plug
B-MAX REPAIR
I DONT KNOE WHAT MERC GETS FOR THAT KIT BUT THE FITTING FROM WEST MARINE IS 26.00.AND YOU STILL MUST MAKE YOU OWN HOSE. I DONT THINK YOU CAN GET ANY CHEAPER THAN THAT.
Ginger or Mary Ann?
TAZ,
I bought my hose from Overtons. It is complete with 3' hose for $15. My cap did only screw on by 2 threads, so I ran a pipe tap deeper for a piece of mind.
Sydwayz is right on the slow draining of cold oil. I try to drain after returning from lake.
Jerry
http://www.overton.com/cgi-bin/overt...arge.cgi?30334
[ 02-01-2002: Message edited by: US1 Fountain ]
Jerry
B-MAX REPAIR
US1 WOW I JUST LOOKED IT UP YOUR RIGHT.I CANT BELIVE THEIR THAT CHEAP.I SEE WEST MARINE HAS A COUPLE OF SIZES THAT OVERTONS DONT.SOMETIMES I NEED TO SHOP MORE.
Charter Member #927
I made my own. I just bought a new drain plug, drilled it out the tapped it. I put a shut off valve on the end of the plug then a hose that I could pull out the bilge drain hole.
I just went back to the old way ,sucking it out, I got tired of the oil seeping out of the hose and makiking a mess out of my bilge. I couldn't get 2 hands down there to put a plog in the end of the hose. If you can reach the end, you can stick a cork in it.
Ginger or Mary Ann?
Since I just push it back inside thru the drain hole after draining the oil, it just lays on the bottom. It doesn't move around or anything either.
