Engine Parts list
Engine Parts list
I was thinking about having a new motor built - does any one have a complete list of parts required to build a carburated engine? If its too long to list, please email me, [email protected]
Thanks in advance
Thanks in advance
I came across this list, just in case anyone was interested in building an engine.
VALVES
VALVE SPRINGS
RETAINERS
LOCKS
INTAKE
CRANK
RODS
PISTONS
RINGS
BEARINGS
CAMSHAFT
LIFTERS
TIMING
CAM BUTTON
CAM LOCK PLATE
PUSHRODS
OIL PAN
OIL PUMP
OIL SHAFT
OIL FILTER ADAPTER
VALVE COVERS
GASKETS
DAMPER
TIMING POINTER
ROCKER SYSTEM
HEAD STUDS
INTAKE BOLTS
PLUG WIRES
WIRE LOOM KIT
DISTRIBUTOR
DISTRIBUTOR GEAR
SPARK PLUGS
STARTER
FLEXPLATE
CARBS
CARB LINKAGE
DUAL FEED FUEL LINE
FUEL PUMP
FUEL PUMP ROD
FLEXPLATE
FLEXPLATE BOLTS
VALVES
VALVE SPRINGS
RETAINERS
LOCKS
INTAKE
CRANK
RODS
PISTONS
RINGS
BEARINGS
CAMSHAFT
LIFTERS
TIMING
CAM BUTTON
CAM LOCK PLATE
PUSHRODS
OIL PAN
OIL PUMP
OIL SHAFT
OIL FILTER ADAPTER
VALVE COVERS
GASKETS
DAMPER
TIMING POINTER
ROCKER SYSTEM
HEAD STUDS
INTAKE BOLTS
PLUG WIRES
WIRE LOOM KIT
DISTRIBUTOR
DISTRIBUTOR GEAR
SPARK PLUGS
STARTER
FLEXPLATE
CARBS
CARB LINKAGE
DUAL FEED FUEL LINE
FUEL PUMP
FUEL PUMP ROD
FLEXPLATE
FLEXPLATE BOLTS
Ginger or Mary Ann?
I'm no engine builder by no means, but shouldn't you have 'engine block' somewhere in that list?
