distributor change
MSD makes a marine distributor with a magnetic pick up, only a little more than the Mallory at Summit
http://store.summitracing.com/partde...=22807&from=MG
Scott
Scott
Gone Fishin'
I'm running the Crane Hi6 ignition box with a Crane coil and MSD billit distributor.
The Hi6 is nice because it has the Merc ignition advances programmed into it. Just pick one with the dial. It also has a dial for the built in rev limiter. Adjustable in 100 rpm increments. Easy to use, easy to hook up.
ok guys im not done. if i change to the mallory and due away with the thunder bolt has module advance what do i do? does the mallory need an advance or is that just a timming issue?do i need some type of seperate module or just the dist and coil.
thank you rchevelle thats what im looking for. where did you mount your coil?
