Removing Silicone
Mineral Spirits is actually what's recommended by most of the silicone manufacturers to remove it. I know because I tried doing it by hand and it's a b*tch. If you are working with gelcoat I would guess that it is fine, if not, you'll need to use something else. Good luck and I'm interested in hearing what other products might help.
Official OSO boat whore
3m makes a adhesive remover that works pretty well. Cut off the thick stuff and then let elbow grease do the rest. It's ok on gel too.
You can buy GOOF in a place like Lowes Wal-Marts etc.
I've used it on my gel coat and no problems. You can get it in liquid form, gel and aerosol. The aerosol works well for average jobs that you are not worried about over spray. If not use the gel or liquid form.
Put it on and let it set a few minutes and wipe it off.
You may have to apply it again depending on how thick it is.
Good luck,
Mike
Good luck,
Mike
