BRAVO-ONE LABBED BY Houston Prop
we would keep the pitch up ,but perform some other tricks of the trade to get the rpm and speed up,send me a pm and I will call you tomorrow,going to hit the hay,later Darin
Jim V.
Hello Jim,kim talked to you todayas well I did talk to your helper while you were out to lunch.
sounds like you have some good people working with you ,very easy going.
Darin
Darin
custom labbing,its your choice,but at Houston Prop we will assure you you are fully satisfied with the appearance of your propeller and more important ,THE PERFORMANCE,
PROP TALK
I need some info from you and then we can hopefully use the prop you have,send me your number and the best times to call and I will gladly call you to PROP TALK
Thanks again Darin
Thanks again Darin
