Removing Anti-Fouling Paint on drive..
![Question](/forums/images/icons/icon5.gif)
Ok...I have a relatively newer Alpha One on my 1987 Formula F223LS. The previous owner applied what looks like either a clear or black antifouling paint over the stock epoxy paint. He also left this boat in the water for 2 seasons...yeeccch.. The af paint has become really nasty. I trailer my boat and I want to clean and polish the drive.
Anyway, the hull is in great shape and I am trying to clean up the drive. I tried some acetone in a small area, and it softened and removed the antifouling paint with some serious elbow grease. However, it did not hurt the factory paint. Is there anything else that I can use that won't harm the factory paint underneath? Will "Peel-Away" work? Or should I just keep using acetone?
Any Ideas?
I don't want to sand the drive and paint it if I don't need to. I just want to get the AF paint off and use my rubbing compound to polish it right up.
Thanks!
-Larry
Any Ideas?
Thanks!
-Larry
If its a vinyl based antifouling paint like what I use on drives, MEK will take it right off. Wear gloves and dont breath too much. You can get it at Ace Hardware and Lowes too I think.
I bought paint remover from home depot that was able to rinse off with water put it on and waited a minute then wiped off I was scraping tough areas with an old credit card. You can't leave it on long though . If the drive is original Merc. paint it should work a repaint might come off.
26sonic
04-10-2003 07:16 PM
