Keith Eckert Manifold Headers
Bob, not to change the subject but will my Stainless marine "dry" setup be ok with my new injuns?Someone told me when you get over 512 cubes i need Stellings or Eickerts exhaust?
Looking good there Dave.
Charter Member #40
John, you would probably wake the motors up a little in mid range and definetly pick up hp, especially above 5000. But is it really worth the expense. Your exhaust isn't that old and I think your motors are on a 31 or 32 inch center which makes things a little tight. Didn't Ike look into doing some other exhaust and the Stainless was about the narrowest? If ya need more.....get blown!
Charter Member #40
Mcollinstn you are definetly correct there definetly isn't much room for a compressor in front of the exhaust log. Actually in this case, how many Apache's have you seen with a procharger? Warpaint would be no different....up thru the hatch baby!
Thanks for the ideas Bob. I was planning to plumb in a 45* elbow to kick the front water hookup out but will see what moving the alt. looks like. I suspect with my closed cooling it will be tough.
Dave
Dave
Diamond Member #001
I'm runnning Corsa Captains Call on my Eickerts. Just give Corsa a call, and they'll sort you out. Bob's right, too - the dimensional data is on Eickerts web site.
Diamond Member #001
Originally posted by blue thunder
...interference....the front of the water plumbing at the alternator and fuel seperator....Dave
Originally posted by C_Spray
Eickert makes a tee kit that you can fit to feed the water in between the first and second cylinders. Works neat.
Can't be, that would be too easy.... I'll check into it C-spray, thanks for the tip.
![Wink](/forums/images/smilies/wink.gif)
Dave
