Fuel Guage?
Went for a run this past weekend and the fuel guage is not working. It worked perfectly when I put the boat away at the beginning of November????? The guage is Gaffrig II and it is stuck on empty. Any ideas on where I should start?
Ty
Ty
I would call Livorsi. My 260 has Faria's and the fuel gauge stopped working at the end of the season and for 8 bucks they replaced it. I e-mailed Faria direct. Gaffrig II's are from Livorsi.
Does the sending unit have a float? you may just need a new float on the unit... but if it is a resistance unit... you will probably need to replace the whole thing. Just a suggestion as to where to check. Good luck.
