7.4 compression ratio
Dave,
I am staying with the stock heads.
To get 9:1 with the 119cc heads you will need to change out the flat top pistons.
I did the swap on my old 330.
$250 will get you a set of Kieth Blacks or Speed Pro Hypos...
Patrick
Patrick
I'm interested in this question also. Bought some used large oval 781 heads on e-bay. Want to increase compression ratio from stock 8:1 up to ~ 9:1. 118cc chambers. What are the relative merits of domed pistons vs milling heads? How much can you mill before you get into trouble?
Not sure if you can mill that much on a Gen V or VI head, but I think the older heads have more meat...
I needed new pistons on my 330 so I used domed.
Patrick
Patrick
