repainting/reassembling lower drive units >
Old 02-06-2004, 04:57 PM
Ginger or Mary Ann?
US1 Fountain's Avatar
Do I have to order this 101 lube from Merc, or is it an auto parts stock item?
Sounds like I will assemble, then paint.
US1 Fountain is offline
Old 02-06-2004, 08:15 PM
marinetrans's Avatar
I think Boat Us or West Marine may have it since they sell some merc stuff now. A merc dealer probably has it on the shelf. You can also use OMC tripleguard if someone has it.Never use Neverseize.It will weld your cover nut in place and may ruin the threads. Paint will look awesome too.
marinetrans is offline
Old 02-06-2004, 08:30 PM
Ginger or Mary Ann?
marinetrans,
You mean this stuff?101
The description sounds like the right application.
Thanks!
Old 02-06-2004, 08:45 PM
Yes the 101 is good for cover nut threads and steering cables. Use merc's 2-4-C w/ teflon on studs, bolts, and propshaft. Loc-tite the seals, pinion nut, shift linkage bolts and input yoke threads. Use merc's spline grease on the coupler splines. Use merc's gimbal bearing grease to grease the gimbal's grease fittings.
Mange
Drives and Lower Units
8
10-01-2007 07:52 PM
cig1988
Fiberglass and Paint
10
05-10-2007 02:51 AM
FormulaM2Formula
1
02-28-2006 12:50 PM
Alex17
1
12-13-2004 12:17 PM
Curt
Fountain
24
02-18-2003 08:27 PM
Quick Reply: repainting/reassembling lower drive units
