OT: 98 F250 charging problem
Looking for ideas on what might be wrong with my truck. It is a 5.4l F250. At 3300rpm the battery light comes on and voltage (gage) starts dropping. Lights go dim if I leave it there long enough. Let off the gas to below 3k rpm and idiot light goes off and everything returns to normal. Was thinking belt, but not sure if serpantine would have this problem. What do you guys think? Alternator?
Dave
Dave
Actually Dave I had a similar problem with my '98 Chevy. I took the alternator off my '97 plow truck and stuck it on the '98. That cured the problem. Then I went and got a new alt. for it. I did that after checking battery and ground connections. It seemed that at higher RPMs the old alternator was having trouble providing juice to the ignition and electrical system. Not sure why, maybe more of a drain due to needing more/quicker spark??
Anyway, it your alternator is the problem try to find a used or rebuilt one. New ones are expensive. Good luck.....dude.
Bill
Bill
Sure enough, turns out it was the alternator. Just installed and new one ($125 btw) and everything is a-ok again. Hard to believe I got good advice from a chevy guy
![crazy](/forums/images/smilies/gurn.gif)
Thanks fellas,
Dave
