A list of oil filters that fit 502MAG & 496HO >
Old 06-07-2004, 03:59 PM
Default Re: A list of oil filters that fit 502MAG & 496HO
Hydro,
I couldn't agree more. I think I can just flip my remote mount over and start using the taller filters with an ADVP valve (no drain valve built into most filters) so they don't drain dry and aggravate an already dry start.
Any thoughts/comments on this, can I just flip my 1996 remote 502 Mag filter over so the filter is pointing up? It is all sealed, should work fine I would think.
Thanks very much,
SL
Pismo10 is offline
Old 06-07-2004, 05:44 PM
Hydrocruiser's Avatar
I know the wrench at my former marina did this for customers. It just plain makes sense.
Hydrocruiser is offline
Old 07-14-2004, 01:40 AM
Good post on oil filters, but remember to check the real testing and inspection reviews on the filters on another previous post. Some different brands are built by a few of the same companies and don't test or examine well. We have personally cut open quite a few and were shocked at how poorly and cheaply some were made. I will refrain from naming names but one especially will have you "paying now and paying later"! Very rare that boating conditions will ever overload a filters capacity unless something inside the motor is comming apart slowly, you are running in horrible condtions or you change your oil every couple of years! The most imprtant thing in a boat is change your oil often. Oil is relativly cheap versus rebuilding a motor. Save your money! Change your oil often!!
Just some thoughts by someone who has seen a lot of motors on the inside.
Raylar
Raylar is offline
Old 07-14-2004, 11:32 AM
Forum Regulator
Sydwayz's Avatar
Received 1,260 Likes on 550 Posts
Raylar, name names. No one works for corporate here.
Sydwayz is offline
Old 07-14-2004, 10:45 PM
Sydways:
You don't remember the commercial where the mechanic is saying "You can pay me now, or you can pay me later!" FRAM, FRAM, FRAM.
Raylar
Raylar is offline
Old 07-14-2004, 11:08 PM
Forum Regulator
Sydwayz's Avatar
I would not use a Fram to soak up an oil spill in my garage. I had one explode on my crotch rocket years ago, and it damn near killed me. Thanks.
Sydwayz is offline
Old 07-15-2004, 08:04 AM
Frams are very cheaply built, they often twist apart when you try to remove them. The side walls are very thin. I used to have to pound a long nail all the way thru to get them to spin off. Then I used different brand.
Pismo10 is offline
Old 07-15-2004, 01:37 PM
Rough Seas Lie Ahead
Reckless32's Avatar
You can add Purolator Pure One PL36461 to the list. It has the silicone anti-drain back to keep oil in the filter for those mounted upside down. Plus they're a cool look'n blue...
Reckless32 is offline
Old 07-16-2004, 10:13 AM
articfriends's Avatar
What about the fram hp series of race filters? I have been running the hp-4 race filter(it fits my aftermarket adapter,i'm unsure if it's the right one for stock part #'s) and have never had a problem,they have big oil holes thru return side,a hd shell that's about impossible to crush and supposedly a high flow filter media?
articfriends is offline
Old 07-16-2004, 10:16 AM
OSO Moderator
BillR's Avatar
Fram = Crap!
BillR
'00 Scarab Sport 302 CC
'02 Cigarette Top Gun TS
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR is offline
Quick Reply: A list of oil filters that fit 502MAG & 496HO
