Velvet Drive oil cooler fittings
Are the oil cooler fittings that screw into the Velvet Drive 3/8" pipe thread? I need to buy AN to pipe adapters and want to make sure I bring the right one's.
I am planning on plumbing my engine and tranny coolers this weekend and want to make sure I buy and bring along the right AN fittings/adapters. Unfortunately, I only have access to it on the weekends and it sucks when I don't bring along the right stuff...TIA.
Were doomed!
I think i have an extra hose or two and fittings from my old TRS setup i can check for ya later tonight. But i'm sure someone will know and respond before i get back to ya tomorrow!
![Smilie](/forums/images/smilies/smile.gif)
-Wally
-Wally
They are 3/8 pipe. Make sure when connect the hoses that the oil and water move in opposite directions in the oil cooler. The top port on the trans. is the out or to cooler and the bottom port is the return. Never use thread tape, use Loctite PST 561.
Marinetrans,
You're tha' man, a real asset to this forum. Thanks for the advise.
My manual also says that the cooler lines need to be at least 13/32" ID (.41"). Do you have a preference for -08 (.44") or -10 (.56"), or is either sufficent?
