starter problems
Hi guys, i had a problem with my starter so i took it out and bought a new one, its the high torque, like 8 lbs i think, it goes on a 502, the old one didnt have shims, so i put this on with out them and it makes all kinds of noise, like its not hitting the flywheel property, i counted the teeth on the started and both are 11 and they both go in the same direction, maybe i need shims, but why? the old exact started didnt have any. Any suggestion in what is going on? thanks
BTW i have my arms worse than a crack addict
took the stupid thing in and out like 8 times, im hurting.
i was at the lake friday testing and i think something got caught on my pickup i noticed no water coming out of my pipes as well as 220 on the temp so i shut it down, the boat would turn but not start, so im worried kept trying, starte once but shut off again, then the started just started free spinning, like it was spining but not coming out, tried to hit it but nothing just kept spining , i took the started out and took it to napa, it was $200 and looked identical. There was number on the started that i had. but same teeth on both and same rotation. im confused, i used the same bolts from before, which 1 is longer than the other, but logically that woulnt matter if they go up all the way. right? Dunno what to do.
how is that possible, i checked the oil in my dipstick and not milky at all, actually it looks fine, i have the othe thread going on hydrolocked since the starter wasnt the problem, any help would be great,
