water pressure fix?
installed new exhaust manifolds (rev marine) water pressure went from 18 to 30 wot. if i remove 1 of the 1/2inch pipe plugs on each manifold and install some sort of adjustable valve with it dumping overboard would it lower the pressure to be safe.
Official OSO boat whore
The pressure rose because the exaust is restrictive. It would be best to try to find the restriction and remove it. Anyways, I have a single 1/2" dump valve and it works great on my app.
I'd call the manufacturer and ask them why the tail pipe is causing a restriction. It might be as easy as opening up the water dump hole into the tailpipe. If you have to go with a pressure relief valve Merc makes one. http://www.offshoreonly.com/forums/s...water+pressure
Wett Vett on the board has one also.
Dan
Dan
32' SUNSATION
Dan
Dan
![Smilie](/forums/images/smilies/smile.gif)
this happened after i installed the manifolds, they keep saying i must have did something wrong
.yes i have thought about the merc valve but i want mine back to around 15-18p.s.i w.o.t.
![Frown](/forums/images/smilies/frown.gif)
Zanie
5
03-10-2005 10:58 AM
28Eliminator
11
06-22-2004 10:43 PM
