Cutting Aluminum- some tricks!!
We have a drip line next to the wood blade (big teeth) on our band saw and we saw 1/2" aluminum all the time and we use WD40 to feed the line. works like a champ. Just wear your eye protection, feed slow and keep your damn fingers away from the blade!
Raylar
Raylar
![Wink](/forums/images/smilies/wink.gif)
One place I worked had a sort of miter saw that was designed just for cutting aluminum. It too used a carbide tiped blade but it was about 18-20" in diameter. To keep the aluminum from sticking to the blade we used a special wax or waxy grease. It was in stick form and we'd apply it before each cut.
$3.50 to $4.50 a pound is more like normal aluminum prices unless you have a volume contract.
Scrap is definitely your best bet, so figure up your minimum individual sizes instead of a single block .
Can you use Merc cast iron spacers?
I've got 4.
I've got 4.
