My new AFR heads >
My new AFR heads
My new AFR heads
Old 03-18-2004, 07:00 PM
Tinkerer's Avatar
I don't have them yet but they are sapposed to be here any day. And they are his old heads ( Jim Valakeo - Pro 1's ) These are the heads that he had on his 540's that dynoed at 699 HP last year.
Tinkerer is offline
Old 03-18-2004, 07:50 PM
PatriYacht's Avatar
Originally posted by tomcat
Monty:
Love hearing about that engine, it sounds perfect. Good point about the head studs. I had to change the head bolts under the exhaust ports with the engines in the boat, because I didn't trial fit the exhaust manifolds.
PatriYacht: How high is the Merlin intake? From block to carb flange a Dart is just over 6".
I'm not sure exactly where you're measuring from but the Merlin is 8.75 tall standing on the bench, and 6.5 from top of intake flange to carb flange. I'm going to mount the exaust manifolds before putting the engines in the boat. The Black Thunder has a huge engine compartment.
PatriYacht is offline
Old 03-18-2004, 09:43 PM
Standing on the bench will include part of the manifold base that sits down in the lifter valley. Measuring like this the Dart is 6" from where the intake sits on the front rail of the block to the carb flange.
tomcat is offline
Old 03-19-2004, 06:31 AM
PatriYacht's Avatar
Looking at it that way, the merlin is 8.75. In addition I'm using a 4 hole 1" spacer under the carb. Teague recommended this setup in one of his Powerboat columns and it does work. It idles at 800 in neutral and drops to 650 in gear without stalling or surging. The carb is a 1050 Holley model #8082-1.
Fenderjack
26
04-11-2007 09:44 AM
JasonSmith
10
02-08-2006 08:12 PM
Monty
16
12-03-2004 06:20 PM
aTX427
12
11-07-2004 10:21 PM
traviss
09-22-2002 12:32 PM
Quick Reply: My new AFR heads
