Alum vs Iron Heads >
Alum vs Iron Heads
Alum vs Iron Heads
Old 02-03-2002, 11:09 AM
Sammy
Post Alum vs Iron Heads
Other than the weight difference are there any other advantages using aluminum heads vs iron heads.
THX
Sam
Old 02-03-2002, 11:15 AM
traviss's Avatar
Post
you can run a hair more compression with alumninum.....
traviss is offline
Old 02-03-2002, 12:13 PM
Bruce
Post
Aluminum heads transfer heat from the engine to the cooling water at a much higher rate. I'd estimate about eight times faster. They allow the engine to produce more power per cubic inch and not suffer from heat related failure's. They are a must for high horsepower blower application, in my opinion. Typically, the port design has performance improvements for better airflow. Just bolting a set on an engine without any other modification, will likely not produce any real results.
Old 02-03-2002, 12:47 PM
Sammy
Post
Thanks Bruce, that's great info. I have to admit that my mechanical experience is limited so I appericate any info I can get.
I am having the top half of my 350 SBC upgraded.
It will consist of a new cam,heads,intake and carb. My goal is to make betwen 325 and 350 reliable HP. I have speced out a mild crane cam, Edelbrock alum heads and intake topped off with thier 600cfm marine carb. All indacations point to around 330 hp based on this package.
Sam
Old 02-03-2002, 12:52 PM
Bruce
Post
Sounds like a great package, the aluminum heads will help the engine breath in your application.
Old 02-03-2002, 07:49 PM
mkforsberg
Post
Sammy,
If you are going aluminum look at the edelbrock rpm air gap intake. I have one on my boat and I like it. It really woke up my engine.
Good luck.
Old 02-03-2002, 08:30 PM
Sammy
Post
Flyfast, when I spoke to the Edelbrock tech rep he did not recomend the air gap, eventhough we questioned him. He said to use the Performer # 2701 EPS. I think I'll double check with them again just to make sure. I'm getting to the point where I keep second guesing my self. When it comes right down to it I think they will all do the job. Plus or minus a few HP will not make any big difference..
THX
Sam
Old 02-04-2002, 12:48 AM
mkforsberg
Post
Sam
I have the stock vortec heads with a rpm air gap vortec and the edelbrock 600 cfm marine carb. I don't know what the hp is but the motor is qquick. I first built the motor with a stock type of intake and you can feel the difference with the air gap.
I would like to find out which aluminum heads edelbrock recommends. I would go with what edelbrock recommends. I think they make a good product.
Let us know what they say.
Old 02-04-2002, 07:12 PM
Sammy
Post
Edelbrock recommened thier P.N. 60909 64cc aluminum heads. They also recommened a cam( #2103) but I think we are going to up grade that just a bit. As far as rockers I went with Harland Sharp.
Sam
[ 02-04-2002: Message edited by: Sammy ]
Old 02-04-2002, 07:22 PM
Ultrafine
Red face
Watch buying an Edlebrock cam. I put there cam in my 454 along with the heads and Air gap intake. I followed thier break-in procedures to the letter and the cam went flat. After calling their tech dept they had nothing but excuses. They did replace the cam which I promptly GAVE away. The 454 still sits in my garage full of metal shavings I have to replace the bearings and rings in it now.
Quick Reply: Alum vs Iron Heads
