Alternator 4 wire to 2
Anyone have any idea how I convert my old Merc. 4 wire over to a 2 wire system? I have older Motorola Alternators and want to change over the newer style.
Thanks in advance guys.
Simple. Connect the large (8 or 10g.) orange or red wire to the + post of the new alternator. The large black wire can go to the alternator body ground, - post (if it has one), or the block. The remaining 2 small (14 or 16g.) wires, purple and red, are not used. Be sure to cap these off so they dont short out. They still carry voltage.
Gary
Gary
Dammmm!!! Too simple for my little brain. Thanks Gary. The purple and red are excitation, for what? I was looking at the schematic but just couldn't figure it out.
Red is sensor, purple is excitation (switched ignition). You can use a 4 wire alternator on a 2 wire harness by attaching the sensor terminal directly to the + alt output. But you still need a wire to the ignition (purple) for the excitation terminal. That can go directly to the + terminal of the coil on a Tbolt IV.
Gary
Gary
