Carbed HP500 Cam and valve spring specs
Charter Member #94
I usually don't get a chance to read the tech section very often, so please excuse me if this has been asked before.
Does anyone know the cam specs and part number of the 1998 Mercury Racing HP500 carb motor??
How about the valve spring sepcs and part numbers?
Is there now a better replacement spring for the HP500?
Thanks !!!
Thanks !!!
Abby-someone
Abby-someone
Check this out.
http://www.offshoreonly.com/forums/s...threadid=73706
Regarding the springs, I would definitly go with Isky.
I have two sets of Comp 961 springs as recommended by Teague that I am not going to use. New Teague price less 25%. Also am selling retainers, locks and seals, all new from Teague.
Shawn
Shawn
MarineKinetics
Gordo
Specs for 500 HP
hyd-roller Crane 284/292 .576/.598
Merc #2409-848906A1
Here is the timing card for the 169611
http://dab7.cranecams.com/SpecCard/...B1=Display+Card
#99896
Outer Diameter Outer 1.540
Outer Diameter Inner 1.140
Inner Diameter Inner .760
Damper YES
Seat Pressure @ Installed Height 132# @ 1.906
Open Pressure and Height 414# @ 1.306
Coil Bind 1.085
Average Spring Rate 470 #/IN
There are options that provide increased durability and performance
Bob
Specs for 500 HP
Merc #2409-848906A1
#99896
Damper YES
Coil Bind 1.085
Bob
Charter Member #94
Thanks for the responses.
RMBuilder, Great info. Just what I needed.
Shawn, please e-mail me your contact info to;
[email protected]
Thanks again for everyones help.
[email protected]
Abby-someone
Abby-someone
Charter Member #94
Do you have a particular brand/part number in mind?
Abby-someone
Abby-someone
