502 MPI Fuel Pressure
Are all these pressures at Idle? Both of my motors idle in the 40-42 range but under a load at 3500 both drop to 36 psi. Mine is a 99 cool fuel set up. One pump is new the other is 3 years old. I'm trying to determine if it's worth putting the adjustable reg on, if I already have a pressure drop when the injectors are under a load then adjustable regs will only boost press at idle which is where it's not needed? Built both motors and had ECUs remapped over winter......test and tune time
