fuel pick-up/check-valve?how to tell
My '90 fountain 29' has 2 x 454 mags and the pickups are square block with pipe thread barb screwed into the block and no other features. Can I blow backwards to see ? Aeromotive says remove it before my new pump is in.There is no sock on my pick-ups and it's a 113 gal tank.Thanks
Actually it takes quite a bit to get the check valve to "pop off" if it was there you would know it. Only an experienced date could pull through the check valve.
