Who Rebuilds Marine Carbs?
As mentioned above, look around for a local rebuilder and check prices. Probably in the $100-120 range. You also could call your local marina's, and if they are nice, they may tell you who they use for their carb work.
Originally posted by Gary Anderson
95$ for a rebuild kit? It should be about $30! Get the serial number off the carb and try a NAPA auto parts store. It's actually a Carter AFB carb that Merc painted black, now rebadged as an Edelbrock. They've been around since the early 60s so parts/rebuild kits are not a problem to find. It comes with instructions that are very easy to follow.
Gary
Gary
You can also get the kits from www.boatfix.com-just got two last month. I think they were around 27 bucks each.
The kits come with a "universal instruction sheet" that once you circle the sections that pertain to your carb it's a no brainer.
Really.
And as long as you keep all of your parts in coherent piles (what came out of it VS what came with the kit) then if you give up it is still easy for somebody to come behind you and do it.
Really.
Insptech, are the ones you rebuilt webers and do you remember what the kit part numbers were? I'm ready to rebuild it but the kits I found specific to my weber are $85 and up.
Thanks to everyone for all the info.!
klmken
05-24-2005 08:19 AM
Donzi Black Widow
12
11-02-2004 12:02 AM
