some problems twin 454 wellcraft
ya the tachs do flutter. drop maybe 300rpm then back up. o.k. for 3 seconds, rpm drop on other side , rpm back up, o.k. for a while , then drop!
but yes i will be there again tomorrow. to start recomission. i will check all fuel related links. and if i find water then dump carbs! think i will get this straighten out ! dam i hope so.
My first thought was what Gary said. Disconnect the synchronizer. You said it bounces back and forth from engine to engine. Sounds a little too controlled to me.
Too controlled for a water problem. Don't get me wrong though, check for water, but disconnecting the synchronizer is easy, and if it is the problem, the results will be immediate.
Paul
Paul
jmorriss103
01-08-2008 07:57 AM
