multi viscosity motor oil
What kind of earl you run? I know, the book says Merc recommends single grade blah blah, I filled up with Valvoline 20/50 full synthetic racing oil. What I've noticed already is less smoke/vapor coming from the crank vents in the valve covers.
Thoughts?
Thoughts?
If you use conventional oils, use a straight weight.
A synthetic will be listed as a multigrade, but they are still a "straight weight" for the most part.
77Superboat
4
01-14-2002 11:18 PM
