EGT's ,,,why so many diff. #'s??what's hot >
Old 04-08-2004, 04:42 PM
HPJunkie's Avatar
NGK r5671a-8 is what ive been using, not projected tip. I think that the stock # is 4554.
Strip Poker,
Are you saying I might be able to run projected tip in an 8 or 9 and get better readings?
OR..are you saying I might try 7's not projected to get rid of the soot on the plug and get better readings?
Thanks Greg
HPJunkie is offline
Old 04-08-2004, 09:06 PM
Rob
Strip Poker 388's Avatar
You can run the projeted tip it will keep the plug cleaner ,not load up at idle, I ran theR5674 # 8's on a 494ci 8/71with 2 1050'c at 11 pounds of boost at 828hp on pump gas. If I did not have verry much idle time I would have went with the 9's. a 9 would shoot up pretty quick at idle though.
or try the 7 in the non progected tip but be carefull.It may be cleaner at idle but maybe to hot at midrange on up.I think # 6 is a stock heat range on most stock engins.
I have used to 3 diffrent dyno shops and they usally went to the projected tip plug on street or marine aplication where there was idleing. Or if there was not enough plug to piston clearance use the non pro.
You might give NGK a call the guys name there is Neal ,hes pretty sharp. Susan used to be in tech she use to sponser me on the plugs back when we ran the Hot Rod street car shoot out circut.Shes in sales now, so no more free plugs .It was good while it lasted .I still have a few odd ball plugs they sent me to try.
One of the good things about the Race NGK plugs they are shorter than any other plug ,nice on the headers, there race plugs are made in a diffrent plant than the regular plugs also.
Lean was too mean. It was still running and not missing either ,The new gapless plugs.picture
ROB
Attached Thumbnails EGT's ,,,why so many diff. #'s??what's hot-pistons-spark-plugs-011.jpg
Strip Poker 388 is offline
Old 04-08-2004, 10:06 PM
HPJunkie's Avatar
Wouldnt the projected tip run hotter? Im not sure Ive got the jist of it .Greg
HPJunkie is offline
Old 04-08-2004, 11:54 PM
Rob
The projected tip sticks out into the chamber . ie more pron to detonation, but it will run cleaner sticking out in the flame . on the colder plug the porcelain goes deeper into the plug. I am not to good explaining things. the temp of the plug doe sent determined by the tip.
you might want to go to a auto parts store and look at a plug like ac 45 style . get one like a 41-43 then go up to 46-48. the #'s might not be correct but would get the idea.you will be able to tell the diff in the heat ranges. try some of the spark plus sites ,they may have some picks also.I probably confused you.
Old 04-09-2004, 08:05 AM
MarineKinetics
rmbuilder's Avatar
"Wouldnt the projected tip run hotter? Im not sure Ive got the jist of it .Greg"
No. Extended tip plugs are actually cooled by the incoming intake chage and provided you have the correct length, and no threads are exposed to the combustion chamber, will resist detonation.
Bob
rmbuilder is offline
Pro1
6
03-25-2008 03:22 PM
Tony Montana
Powerplay
5
06-05-2006 08:54 PM
Rookie
2
06-22-2005 08:26 AM
Jassman
26
01-04-2005 06:05 PM
WES311SR1
04-27-2002 08:39 AM
Quick Reply: EGT's ,,,why so many diff. #'s??what's hot
