Motor idling fast after exhaust & plug change?
Replaced my stock 3" exhaust & risers with an aftermarket (but basically stock) 4" system, including exhaust hose (no mufflers now or prior). Also changed spark plugs to RapidFire's (#1). I made no other changes to any component.
Now, motor idles fast (1000 rpm vs. 850 rpm).
Must I adjust the carburetor and/or the timing due to these changes? Carburetor is Holley 750cfm double-pumper (3310).
Thanks in advance,
D. Ocean
Pompano Beach, FLA
Thanks in advance,
D. Ocean
Pompano Beach, FLA
I think you must have been running a little rich. With the changes you made you just leaned the motor out a little and it needed it therefore the gain in RPM's....I think it's
as simple as that. Just reset your idle air screws to get the highest vaccumn at idle and you should be good to go. I don't think you need to touch the timing at all. But always good to double check and make sure.
BH
![Roll Eyes (Sarcastic)](/forums/images/smilies/rolleyes.gif)
BH
I would check with your manufacturer of the exhaust and see if they recommend changing the jets, you do not want to run a lean motor.
I would run her for a day and pull a plug and check to see if she is running lean.
Yeah definitley check the plugs...You don't want to run too lean.....Should have mentioned that
As long as they look good then just adjust your idle-air screws to get the highest vaccumn at idle....
BH
![EEK!](/forums/images/smilies/eek.gif)
BH
