Fuel Pressure Sending Units
Official OSO boat whore
I have a dual port regulator. The sending unit comes directly out the second port.
if you have a regulator bypass it is located on the regulator itself, otherwise you will want to place your sending unit as close to the carbs as possible.
see the brass plug this is where the sending unit screws into, the bottom plug is for my return line back to my tank since i run an electronic fuel pump.
