Compression #'s and blowby
If a motor has good compression numbers, but has a good amount of blowby at idle (through the PVC valve), does this mean there could be a valve seat problem or a sticky valve?
Toxic FORMULA
Probably not. That would cause blowing into the intake or exhaust passages not the crankcase.
What kind of compression numbers are you talking about? You should truly do a leakdown test.
Originally posted by HARRISONMIRAGE
Blownboat I don't know what ttt stands for either but I gather it is a meens of getting your post to the top of the list if the thread is dieing?
