Houston prop >
Houston prop
Houston prop
Old 04-20-2004, 11:34 AM
What does the polishing do besides make the blade pretty? Just curious. I guess what I am after, is....what percentage of the performance gain comes from the labbing and what percentage from the polishing? Thanks
justinVIP is offline
Old 04-20-2004, 12:22 PM
mlitefan
Default Re: Bravo-Rator
Originally posted by HOUSTONPROP
I would have mentioned it if I thought this is what you needed.some do and some don't just depends how close you are and what the prop is doing?? blowing out ect.
yours did not need drastic changes.It will be fine .
Thanks Darin!
So you only had to hit mine with the 8 pound sledge instead of the 15?
Old 04-20-2004, 04:48 PM
HOUSTONPROP's Avatar
polishing makes the prop stronger as it closes the scrathes and reduces the chance of stress risers.
% don't knowbut it better.less chance of wiping out the outdrive with a thinner prop than a stock prop that is extremley thick.
HOUSTONPROP is offline
Old 04-20-2004, 04:50 PM
Default Re: Re: Bravo-Rator
Originally posted by mlitefan
Thanks Darin!
did we pitch your prop.
Old 04-22-2004, 03:23 PM
mlitefan
Default Re: Re: Re: Bravo-Rator
Darin, just wanted to let you know the prop arrived today. Dauuuum does it look sweet!!!
I must say, I was very surprised. There only seem to be a few hammer marks and all the blades are still there....
Just kidding, of course. I will put the boat in the water tomorrow and let you know how it runs. 68 GPS was the norm last year. Weather looks good, should be a nice light chop. If it runs half as good as it looks I will be stoked!!!
Old 04-23-2004, 12:02 AM
Default Bravo-Rator
it's new and has worked on quite a few boats.
lets hope for the best on yours.let us know ,also do you have a picture you can post .?? I, keep forgetting to take one of this design.
found one.
Old 04-23-2004, 12:38 AM
Default Bravo-Rator & ACCLERATOR
Bravo-one, conversion to the BRAVO-RATOR
by Houston Propeller
for a quicker holeshot and cruising speeds with high x dimension's, excellent midrange and top speed gains.with superior Bow and stern lift.
The ACCLERATOR IS ON THE left.
excellent holeshot (no-blow-out) fast setback in midrange accleration with excellent top speed gains of 3 mph and above.
Old 04-24-2004, 02:10 AM
Default Bravo-Rator
this design has a very aggressive cup on the tip of the blades only,creating slip, as it grabs the water shooting out on plane very quick with no to minimal blow-out,acceleration is awesome with great OVERALL LIFT for increased speeds.
the wood floor is not included.
excalibur al
164
05-18-2006 08:28 PM
DLRVelocity1
2
08-28-2004 11:31 PM
wwwTOPDJcom
07-15-2004 07:32 PM
Blade38
03-28-2004 08:06 AM
290PQ
1
05-19-2003 12:47 PM
Quick Reply: Houston prop
