Interesting OEM 522 Whippled EFI engine build.
#31
Re: Interesting OEM 522 Whippled EFI engine build.
Putting the balancer back together. Engine is balanced with only the counterweighted center section.
#32
Left one cylinder head off until I had the timing cover and balancer. Need to use the piston stop tool to find exact TDC.
Found it. You might notice the engine changed color also.
#33
The GM Gen VI timing cover has a pointer built on. The stock balancer is 8" and the new one is 7" . Will not work. Was worth a try.
#34
A quick cutting wheel job on the stock timing pointer and a new billet adjustable pointer will do the job.
#35
Installed the other cylinder head, remainaing valve train and timing cover for good.
One last look around in here.
#36
Should not be a problem filling these cylinders. What looks like a step is a digital camera optical illusion. The black is the hard anodizing. The entire head casting was hard anodized before machining.
#37
Thanks GM for providing this intake valley pan. It is a nice feature. Will keep the hot oil from splashing the bottom of the intake manifold. The intake will have an integrated intercooler as well. Every little bit helps.
#38
Better update some posting on this project.
Will be fairly direct and to the point.
Dooley supplied pan pick up.
